Posted by Bigdog on August 20, 2009 at 11:20:00 from (71.64.18.18):
In Reply to: Cub fuel flow question posted by Rodger In Sabula on August 20, 2009 at 05:29:56:
If the carb inlet screen is clean and the flow is good that far remove and clean the main jet on the carb. Clean both openings with a soft copper wire such as a small telephone wire. Do not use anything made with steel you do not want to damage the openings. You probably have a small piece of dirt partially blocking the jet.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
