If the new tube can be fabricated I would still consider brazing.
To butt-join two tubes I'd find the next size of tubing and make a sleeve - similar concept to copper sweat-solder coupling, although I would use steel.
If you have to go back to the end block on the pump, I'd carefully bore or ream the block for a very close fit (tap fit, very slight press) and then braze. Tig welding is always a possibility (the demo pieces are out there of aluminum pop cans and gum wrappers tig welded together) but a greater skill level would be required...brazing is going to be a process that's much more forgiving with a thin section in my opinion.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
