Hi Jim, you have to cut the pipe that goes from the pump, weld a fitting on the pipe( pump side), run a hose from the fitting to the IN of the control. Weld a fitting on the pipe that goes to the hitch valve, run a hose from the OUT on the control, to the fitting, for a open center circuit. If you tap on the pressure pipe,like a T, it have no pressure until you lift a weight with the hitch arm. Bernard le mecano Quebec Canada
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
