Re: Stuck sleeves in a SA
Posted by ScottyHOMEy on August 03, 2009 at 15:42:45 from (70.105.226.246):
In Reply to: Stuck sleeves in a SA posted by TWheat on August 03, 2009 at 15:03:03:
Actually, one of the tricks for gettin them out is to weld a bead or two up the inside. When everything cools any corrosion holding them will have been broken up with the heat and cooling cycle and they will have shrunk to where they should come out without much diffugulty a tall.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
