Posted by screwstick on July 29, 2009 at 19:02:27 from (75.89.23.145):
In Reply to: cub 154 low-boy posted by stephen roberts on July 29, 2009 at 17:28:14:
Before advice can be given, you should do a compression check, wet and dry, check the valve clearances, direct oil pressure check and do a tune up; plugs, points, rotor, wires, cap and coil (the works). Check timeing as well.
This will be much cheaper than rebuilding or replacing the engine. If all is bad, I would rebuild the engine if the clutch, PTO and mower deck are still in good shape.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
