If it has power steering one way but not the other it is not the pump or relief vave. I would check the splined knuckle on the front end of the steering shaft. Those splines cannot be froze to the steering valve input shaft. That input shaft has to move laterally in or out as you turn the wheel left or right. That input shaft moves the control spool inside the control valve. If that knuckle is froze to the input shaft and the u-joint at the suport bracket mounted to the starter is not adjusted correctly the snap ring on the upper end of the steering shaft will limit the lateral movement of the steering spool and cause the problem you are experiencing. Chuck
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
