When it quits pull one of the plug wires & check for fire to your plug, do this asap before it cools. If there's no fire replace the condenser. If it keeps quitting you need to make sure battery voltage is still getting to the coil. Use a test lite or volt meter & with the points open you should have voltage on both small terminals on the coil. If you have fire to your plugs you have a fuel problem. Look in the tank with a good flashlite to see if any rust or dirt is covering the outlet. Pull the gas line at the carburetor and see if there's a full stream of gas there. If that looks ok check behind the tube fitting where your gas connects and see if there's screen behind it that may be full of crud blocking the fuel flow. Hal
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
