Posted by AB Morrow on July 03, 2009 at 10:57:22 from (216.220.4.62):
I am having problems with the power. Cannot get spark to the points. I've changed the points and coil but have not replaced the condenser. The system had been changed to a 12V with a resistor. I have checked the voltage at the coil and am getting 6.25 volts. I started the tractor and it ran for about 2 minutes and then quit and I haven't been able to get it started again.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
