Re: Farmall H Connected battery Backwards
Posted by RyanT on July 02, 2009 at 17:06:06 from (74.212.19.149):
In Reply to: Re: Farmall H Connected battery Backwards posted by Brownie 450 on July 02, 2009 at 16:58:10:
Yes, everything is clean and tight. I even disconnected the battery and clean them....that is when I realized what i did.
Battery must be shot. So i will need to buy another.
Hopefully there isn't any other damage to the generator.
Ryan
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
