Mike. I would not run the tractor any longer before knowing what is wrong. Probably either a bearing or a gear has failed. Further use might cause far greater damage to gears, shafts or castings. As a first step, pull the transmission cover and peek inside. Put it in gear, keep the clutch down and rock a rear wheel back and forward while peeking inside. I don't know whether one can see the bull gears and the differential after having removed the transmission cover; for this you may have to pull the PTO assembly. Hope SC experts chime in. HTH, Hendrik
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
