Re: Super C lopes under load
Posted by Brownie 450 on June 23, 2009 at 05:30:10 from (216.51.158.199):
In Reply to: Super C lopes under load posted by Etnfarmboy on June 22, 2009 at 20:38:39:
Sounds like carb fuel level not high enough. Wouldn't overlook the point gap being too narrow, though. Points are easier than carb to look at/ adjust.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
