Posted by Janicholson on June 18, 2009 at 16:55:32 from (66.173.50.162):
In Reply to: Re: Farmall M. 1948 posted by Bob Lanford on June 18, 2009 at 12:45:45:
The seal is easily changed. caseih.com choose your country, then select parts and service tab with pull down menu. select parts. on the next page choose "begin your search here". in the box put Farmall then scroll down to M then choose chassis then choose transmission The clutch pictures may also help. This gives numbers and exploded views. Pull the Belly Pump. Take out three of the clutch pressure plate bolts (at 120 degrees from each other) this leaves 3 other bolts. Put these bolts into the back of the Pressure plate (there are three holes with threads) this releases the clutch (pushes in the fingers), and allows the clutch shaft to be removed. Remove the four bolts holding the drive coupling together. Take pictures of the assembly to assure reassembly in the correct orientation of the drive plate in this joint. Remove the clutch shaft (it will come out it is a geometric puzzle, but done quite often world wide! Now the retainer is easily accessed to change the seal.Many bearing and NAPA stores will be able to cross the number. Other directions are in the archives for removing the pump, (heavy and awkward) I hope this helps, JimN
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
