Posted by teddy52food on June 16, 2009 at 18:54:07 from (209.237.111.169):
I don't know what I did wrong, but I got it out of time somehow. The mag is used with a coil as a battery ign. The impulse is very weak & didn't retard the spark & it would sometimes kick against the starter. I took the mag off & the fly weights in the impulse are worn real sloppy. I robbed the impulse from a parts mag & put it on. They both are the same. Key slot is the same, dogs are the same etc. Put it back on the tractor & it really kicks against the starter. When I took it off I noted where the rotor was pointing and the mag has a mark that lines up with a mark on the housing. So I know I got it on the same as it was. With the ign off & the cap off, using the hand crank, the impulse trips when the piston is half way up. #1 plug is out & I lined up the flywheel at tdc & it seems like the mag is off about 90 degrees from where it should be. Any ideas?
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
