Is it a 2 wire cutout relay charging system that used the LHBD light switch that controlled charging (Low or High) ORRRRRRRRRRR did it have a full fledged 3 or 4 terminal Voltage Regulator?????
A good and charged up 8 volt battery should read around 8.4 volts just setting there tractor not running BUT to charge it when its coupled to a good generator and the tractors runing at fast RPM the voltage should rise to 9 to near 10 volt range IF IT DONT DO THAT ITS NOT CHARGING THAT 8 VOLT BATTERY
If its the older cutout realy and LHBD light switch assuming all is well and its wired right, the old 6 volt genny can still charge that 8 volt battery although its not gonna charge at real high amps.
HOWEVER if it has a full fledgd Voltage Regulator with EITHER a voltage control relay OR a combination Voltage/Current control relay IT SHOULD BE ADJUSTED FOR BETTER CHARGING
If you already had charging problems with a 6 volt battery THEY ARENT GONNA GET ANY BETTER USING AN 8 VOLT BATTERY................
See what happens if when shes running you temporarily dead ground the gennys FLD post to frame ground???????? If the ammeter then shows a good charge and the battery voltage rises to 9 or more THE GENERATOR IS OKAY so the problem is the Voltage Regulator (If you have one that is) If dead grounding the gennys FLD still dont make her charge then the problems more likely the genny is bad unless the cutout relay isnt closing.
On 6 volt systems I recommend the biggest heaviest battery that will fit plus use 00 gauge cables.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
