Hi, cut the pipe that go from the pump, hitch one,weld a fitting at the cut end, run a hose, from the fitting, to the IN of the loader valve.On the pipe, that go in the hitch valve, weld a fitting too, run a hose from the OUT of the loader valve, to the fitting weld on the pipe to the hitch. The best place to cut, is under the fuel tank.Now you can run the loader and the hitch without turning knobs. Bernard le mecano Quebec Canada
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
