The tip of the lever is usually OK. The wear is mostly on the sides of the ball at the end of the lever. If this has only happened once, I wouldn't worry about rebuilding the tip of the lever. If it happens repeatedly you might want to try reworking it and checking condition of the rails and brackets.
You need to make sure all 3 forks are in the neutral position on the lid. The 1-2 and 3-4 slider gears need to be positioned in the center of their movement. The reverse slider needs to be at the end of it's movement (to the rear as I recall). With the clutch blocked down, the input shaft should be able to rotate freely. Then lower the cover straight down into position. Stick a couple bolts in then try shifting through each gear. If it moves into and out of each gear, you have it. If not, you probably missed with one fork and need to try again.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
