Posted by Hugh MacKay on June 12, 2009 at 18:13:12 from (209.226.247.35):
In Reply to: 340 tel-a depth posted by Richard rice on June 12, 2009 at 16:58:08:
Richard: You changed the tele-a-depth unit to a regular hydra touch unit, do you mean control valves or entire unit? If that be the case then why did you replace the cable? There is no provission on a regular valve for attaching the cable. This requires a bit of clarification.
To me it sounds as though you have some plumbing wrong.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
