If it's the former forget about a 12 volt generator! An alternator does better job keeping the battery charged, provides more power for lights, etc. and will last longer/require less maintenance. It’ll also be cheaper than a generator.
Tip: Use a 3-wire rather than a single wire alternator. A 3-wire requires a few more feet of wiring plus a warning light or diode. But it will be cheaper and it will avoid the annoying issues single-wire alternators frequently seem to suffer from.
If you elect to stick with a generator most any Delco generator from a tractor or GM car from the late ‘50’s/early 60’s will work (IHC, Deere, Case, MM, Oliver, etc). You might need to reuse the fan/pulley assembly from your 6 volt generator however. Make sure you get the matching regulator too – otherwise the smoke may be let out of the generator!
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
