Most definately a bearing, probably the inner axle bearing, came apart. The balls try to wedge in between the bull gear and the housing and the housing loses.
How big a hole are you talking about? If you have the piece it could be welded back on or I've seen patches fabricated to go over such hole, but not as pretty.
By $600 for a parts tractor do you mean buying another tractor for parts to fix this one or buying this one for $600?
You'll want to pull the platform off to see if there is any damage to the bull or pinion teeth. Sometimes the ball can get wedged in the bull gear teeth and then go through the bull/pinion mesh.
With the platform off, the wheel bearings are not hard to change. If the one was worn loose enough to come apart, others may not be far behind. If you shop around you can find a domestic made inner bearing in the $90 dollar range. The inner bearing is a 214W. The "W" means it has more balls and thus a higher load capacity. The outer would be a 214D, it has a shield on one side to help keep the grease nearby. You can use the inner on the outer side for more load capacity, would be a 214WD!
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
