If I am reading your post correctly.. your rim pocket won't keep the bolt from turning.. so you cover the pocket with a washer.. then insert the bolt. this holds the bolt out so you can get a wrench on it while you tighten it. Am I correct? If so... Then you MUST get rid of that washer and get the bolt head seated against the hub. I wouldn't even bother trying to put a nut or anything under it to build it out.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
