Posted by pete 23 on May 18, 2009 at 16:44:02 from (173.87.14.132):
In Reply to: SuperH Heads posted by SuperHank on May 18, 2009 at 13:54:56:
There is a slight vacuum on this tube as it leads to the inlet pipe on air cleaner and as an engine will normally have more blow by than the amount of air passing through the tube you still need another vent for crankcase. Breather on side has a filter element in it also (chore boy) to keep the dirt out in case there would be a reverse flow. When the 460 and 560 came out they also had a vent tube to air cleaner from valve cover, but soon learned it just lead to more build up inside air cleaner inlet pipe and took it off and plugged hole at air cleaner and valve cover.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
