Posted by GordoSD on May 16, 2009 at 16:11:11 from (66.115.200.140):
In Reply to: Re: Planting time posted by Rootsy on May 16, 2009 at 14:50:13:
I put 150 lbs of urea fertizer in each of those pesticide hoppers. Have both valves almost wide open. It helps hold the planter down, for min til, and "strip fertilzes" at the rate of about 60 lbs per acre, which would probably be 100 lbs broadcast.(36 inch rows) I just do food plots for wildlife so 80 bu corn is adequate. Plots are either 6 acres or 2.5 acres. Seven of them. You can't get those hoppers clean enough when you are done though. And store them INSIDE when not in use.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
