Posted by Welding man on May 16, 2009 at 13:53:33 from (65.216.168.2):
Have a 1066 with gear drive transmission, that is giving me a fit. Was wondering if anyone else has run into this problem.The same pump operates the hydraulics, steering, brakes and TA. When parked on level ground or nose down hill, you can start the engine and everything works. If you park nose uphill or drive up a steep hill nothing works. When everything is working properly the pump pressure checks within specs. The oil and filter has been changed, the pump has been pulled and inspected and new gaskets and o-rings installed.The oil is filled to the correct level. It appears that the pump is sucking air when the nose is up hill, but I cannot find out where. Any help would be greatly appreciated.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
