Posted by paul smta on May 16, 2009 at 12:56:27 from (68.117.10.58):
There is a resistor block between the 12 volt power source and coil reducing the voltage to 6volts I checked this with a meter.My question is this a 6 volt coil? Can I elimate the resistor block and run 12 volts thru the existing coil or do I need to up grade to a 12 volt coil,to the best of my knowelge this tractor came from the factory with the option of a 12 volt system.I am running a petronix pointless ingition and autolite 388 plugs gaped at .032 but the color reading after 1 year of use indicates not enough fire in the wire,this tractor is used very little and not worked hard.Any input thanks.Paul
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
