Matt: One item you should remember about transmission and final drive leaks on offsets. 65% of them are created by transmission being over full. When the transmission is over full it leaks down and over fills the final drives.
On the bottom of the transmission you'll find an open port, supposed to drain off excess from transmission. When the chanels to that port are plugged, excess oil from transmission goes to final drive, usually the left one first.
Fill to level and fill plug on final drive are on front inside of each final drive. Takes a 1/2" drive to remove it. To drain a final drive you must remove the sump pan.
Fill to level plug for transmission is just below front tip of left fender, on side of transmission case and behind brake activation rod.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's.
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
