Re: 130 governer spring
Posted by Bob on May 08, 2009 at 05:02:26 from (69.178.228.68):
In Reply to: 130 governer spring posted by Kerry (N.S.) on May 08, 2009 at 04:19:50:
The governor ball thrust bearing CAN fall apart,but only if it is worn out anyhow.
The biggest deal will be timing, if the shaft is removed. Easiest way is to put the engine @ TDC, then note EXACTLY where the drive is at.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
