to slow down the speed, you would want a smaller sprocket on the driver, and/or a bigger sprocket on the driven side. the speed should be independent of the seed size. the plates need to match seed size for the correct seed placing. 1 seed per notch (loose but not enough room for a second seed to try and wiggle in here and there). i don't have a manual for your planter, but a crude way to check population would be to run it in the driveway and play with sprocket combinations to get 1 seed every 5-7". hth
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
