What is the quality of spark when the tractor dies? Your tractor came from the factory with a 6 volt system. It now has a hybrid 12 volt system. Are you using a "true" 12 volt coil or a 6 volt coil with a resistor? If you are using a 6 volt coil, then the resistor must be matched to the primary resistance of the coil. Just any resistor won't do. Does your system use a resistor bypass for starting? These can be misleading as you will have good spark while the resistor is being bypassed during cranking, but weak spark on run.
If this checks out ok, it is probably time to take the manifold off. With the manifold off, I usually fill the exhaust side with water and see if it seeps into the intake side. No pun intended, but I would exhaust all ignition possibilities before tackling the manifold. Let us know what fixes it.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
