As Hugh and TV have indicated, you have a problem with the tel-a-depth system. If it is an International (read utility) I don't think it has the gears Hugh mentions, at least mine doesn't. If Farmall (row crop) it does. Look at the hyd cylinder and see if there is a mechanism attached to the top of the cylinder -- that is part of the tel a depth. Also check the linkage. Make sure the hitch is in the float position. But, you really need a manual, hard to explain without one. I had a similar problem with mine, but it was caused by the relief valve. If an International, it is behind the battery box behind the seat. I don't know where it is on the Farmall, as I don't have one.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
