Posted by Janicholson on April 15, 2009 at 06:24:42 from (199.17.6.128):
In Reply to: farmall 300 govenor posted by case 385 on April 14, 2009 at 20:26:53:
That is not uncommon. Remove the link from the governor arm (behind gov.) Put the throttle hand lever wide open. with your hand, pull the governor lever to its full open position (internal stop). Now see where the linkage is related to this position. The lonkage needs to be short enough to pull this lever to that full open position. If it does with the pin in it it is as good as it can be. If the throttle lever is going back toward idle on its own, it needs to be tightened (if a friction disk type) or have some filing and possible weldup of the teeth/notch/pawl if a ratchet type. JimN
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
