Posted by the tractor vet on April 14, 2009 at 07:02:27 from (76.212.233.212):
In Reply to: Re: pto problems posted by davin003 on April 13, 2009 at 19:53:59:
Well , I told ya all that i can as there is not much to them units so if everything is as it should be and the pick up tube is snug in the clamp the tube does not have a flat spot and in the correct position and does not flop around as this will cause the seal to suck air as it just sorta sets in the bore and the pump is good ya got the valve put back together correctly don't know what else to tell ya as like i said i CAN'T see it. It takes me about two hours from the time i start with draining the oil to the time it is running in the tractor again. Did ya check the brake piston's ? last thing as to where the oil pressure could get dumped . Oh if your going to replace the teflon seal rings on the clutch drum it helps if ya soak them in hot water - oil to warm them up then use a piston ring compressor to shrink them back into the seal ring groves . and be care full when reinstalling the clutch drum back into the housing so not to damage the seals . I use white grease on theses .
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
