Oh well then that explains it all . I'll bet the hyd. oil looks like MILK . And more then likely it has been COLD there . You have water in the system as that tractor will condensate bad and water builds up inside the tractor . SOOOoooo ya just might as well plan on draining the system and replacing the oil . If you do not have and owners manual then it will be money well spent and set down and read it cover to cover . Also buy and IT manual for it . Since you do not run the tractor enough to really cook out the moisture you will always have problems with any tractor . It would be in your best intrest to find a good trust worthy mechanic to come out a couple times a years and service it . The hyd. filter will do it's job on catchen water But it will require changing a lot more often then a tractor that is worked hard. This also apply's to engine oil changes and fuel filter changes. I am sure that you will find ICe in the filter for the hyd's .
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
