Regardless if its a 3 terminal Voltage Regulator or the older style Cutout Relay, theres usually ONLY ONE wire on the ammeters SUPPLY terminal and that gets to the hot ungrounded battery feed usually via a wire down to the starter where the big batery cable attaches,,,,,,,,,The ammeters other LOAD terminal wires to the BAT terminal on a Voltage Regulator PLUS feeds hot battery voltage to loads like lights and ignition. IE the gennys output PLUS the loads all wire on the ammeters one terminal opposite the other supply terminal.
If it reads bass ackwards, simply reverse the leads. If its wired right if you turn on lights or ignition when shes not running the meter should swing to - discharge but then when running at RPM if shes charging it will swing to + charge, again, if it does opposite reverse the leads
No it wont damage it, just read bass ackwards
When they are converted from Pos to Neg ground the ammeter leads need reversed, of course
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
