The adjustment screws should be clearly visible. Apparently the previous owner found a clutch that "fit". If so it is not the correct one. Have you tried adjusting the linkage between the pedal and clutch shaft? Also in some older clutches there are bolts that compress the pressure plate until the clutch is installed, then they are supposed to be removed.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
