I agree with the others on the cause. The arrowed casting boss is the source of the domed chip. Feel in the hole to determine if there is a bolt occupying it. Do this from the inside with a piece of stiff wire, or a good light and better angle. If there is, clean and apply a modest layer of RTV. Let cure and put it all back together. If there is no bolt I would use a small wire brush (3/8" bottle style brush and clean the threads very well (from inside). Then I would run a tap into the hole from the inside to assure it is clean. Then I would take a correctly sized socket head setscrew (about 1/2" long) and use a dremel cutoff grinder wheel to make a screw driver slot in the end opposite the hex socket. I would put #2 non hardening permatex on the threads of the setscrew, and screw it into the hole backwards (hex head first) and tighten it with the screw driver slot. Now you are done. The next person needing the use of that hole will find a convienient way to remove it from the outside. JimN
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
