Posted by Red Mist on February 10, 2009 at 17:12:07 from (72.171.0.142):
In Reply to: Setting Valve Lash posted by Janicholson on February 09, 2009 at 19:29:46:
El Toro said: (quoted from post at 17:46:09 02/10/09) With No1 piston at TDC on the compression stroke you adjust valves starting from the radiator.
Adjust valves 1,2,3 &5 then rotate engine until No4 piston is at tdc which should be one full turn. Then adjust 4, 6, 7, & 8. Set them all at .020" cold . Hal
Good call, Hal. Right out of the IH GSS-1356 Tune-up specs manual. It is easy and it sure works well.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
