If you can pull the new wire in using the old wire being pulled out. If there is no wire, use a piece of electric fence wire or # 12 solid copper and push it in from the outside end. It has to be relatively straight. Tape the end of the #16 stranded light wire to the end and pull it back out. You probably will not be able to push a #16 stranded through the pipe. Electritians have a special flat wire puller made of spring steel with a built in hook in the end. If you can get you hands on one of those it will work best.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
