I am assuming you have the open center system other wise with the pfc system closed center this doesn't work. You need to hook the supercharge line coming out of your aux valve bank into your added valve , go right through while valve is in neutral and back to supercharge line going to mcv pumnp, then have to have a port in valve bank for return flow from valve when in use to return to sump so as not to contaminate super charge line with anything in return flow. A CaseIh dealer should be able to print you a copy of service bulletin S-3436 Dated March 1977 from hydraulic section. It lays it out for you along with options to run an orbit motor. Gets to be kind of a mess but does work.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
