Posted by bc on January 29, 2009 at 08:58:40 from (69.149.215.139):
In Reply to: 560 diesel posted by MN Sparky on January 28, 2009 at 16:52:41:
Guess I'd be more concerned about the pressure of the blowby. Can you hold your hand over the tube for very long and does it leave an oil ring on your hand? Is there oil around the end of the tube on the tractor and on the ground if left sitting for a while?
If you take out the oil cap, does it blow drops of oil out along with the smoke? Is there enough pressure to blow out your oil cap unless it is screwed down to where it is expanded tight?
My gas 2606 does all that along with that blue oil smoke that isn't nice to breathe. After a half hour the smoke isn't as bad but still under pressure. It doesn't use much oil and I don't use it much so I'm in no hurry for an overhaul. It starts and moves hay.
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
