Posted by 1066 on January 28, 2009 at 14:23:20 from (67.142.162.20):
In Reply to: Farmall B clutch posted by 1066 on January 28, 2009 at 10:16:52:
No we didn't the customer thought we could save it. We adjusted the fingers out and now when you hold the pedal down the fingers move away from the adj. bolts. My guess is that the new disk is not compatible with the old Atwood pressure plate. With me holding the clutch pedal down and looking in the inspection cover when you turn the PTO shaft it turns the engine over,it is not even close to releasing the disk. You can see the old marks were it moved before and we didn't get much more release by moving the adj. bolts in fingers out. Time for a new pressure plate I think. Thanks for your help.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
