Posted by James Williams on January 28, 2009 at 13:45:16 from (65.73.216.19):
In Reply to: Farmall B clutch posted by 1066 on January 28, 2009 at 10:16:52:
1066,I had the same problem with a F20,I used a used clutch and a used pressure plate that I bought separate from each other,I had to shim the pressure plate,{or adjust the fingers out more}so the pressure plate would release the clutch.Did you replace both the pressure plate and clutch at the same time.Sometimes saving money is expensive.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
