Posted by Red Dave on January 28, 2009 at 10:46:48 from (66.216.141.163):
In Reply to: Farmall B clutch posted by 1066 on January 28, 2009 at 10:16:52:
The step in the flywheel should be cut when the flywheel is refaced. The dimension is in the repair manual, I don't remember it offhand.
However, if it is not ground, it seems to me that the clutch would slip, not fail to release.
Sounds like maybe a bad pilot bearing, or the pressure plate fingers are not adjusted right. Is the throwout bearing facing worn? That might do it too. I would always replace the pressure plate and throwout bearing with the disk rather than have to go back into it another time.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
