Posted by Janicholson on January 28, 2009 at 10:29:02 from (199.17.6.128):
In Reply to: Farmall B clutch posted by 1066 on January 28, 2009 at 10:16:52:
The clutch disk can be put in wrong. If the flywheel side is not to the flywheel, it will not release. The drive hub rubs on the flywheel mount. This or bad spline wear on the clutch shaft, or a bad pilot bearing will cause the issue. If the disk got bent from pressure during insertion of the engine to trans, the bent hub will also drag on the Drive components. JimN
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
