If you have a ballast resistor in it now, then the coil should be 12v for use with a ballast resistor. If it has no resistor now a coil designed for 12v no resistor required is best. If hand cranked it makes no real difference. Putting a choke cable and control near the front might be a positive addition. Shutting off fuel when it is hot can limit loading of extra fuel into the carb (which can cause hard starting) JimN
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was
... [Read Article]
Latest Ad:
[More Ads]
