Posted by tractorsam on January 24, 2009 at 17:12:01 from (142.177.27.222):
In Reply to: SMD-WD9 posted by henryv11 on January 24, 2009 at 17:01:59:
On the letter series diesels there were two levers used in the changeover. I believe the number series only used one lever.
On a SMD one lever controls the injection pump (as you don't want diesel being injected when it's running on gas) and also acts like a throttle on diesel. The other lever opens the starting valves (a third valve in each cylinder) and operates a butterfly in the inlet manifold to direct air around or through the carburetor as required. The shaft that the butterfly is on also has an electrical switch attached to engage/disengage the mag/distributor. The starting valve opens to an additional combustion chamber to lower the compression ratio sufficiently for it to run on gasoline. Hope this helps, Sam
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
