The main difference is the CP tractor uses bullgear drop housings to raise it up and reverse the operating direction. It uses a 7:50 x 20 single guide wheel. The High Clear uses chain drive drop boxes which do not reverse the operating direction and were standard with a high clear wide front axle.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
