On the BN, your only timing mark is going to be the TDC mark on the flywheel. Unless the tractor's been split and cleaned up, it can be hard to find. It's a line that runs fore and aft on the flywheel, marked T-C 1-4. Turning the motor by hand (plugs out) you should be able to feel the compression on #1. Ge5 to that point and then run a stiff wire or a skinny screwdriver into the plug hole on #1 so that it rests on top of the piston. When the wire is at its lowest point the piston is at its highest, and you should, with some looking/cleaning . . . be able to find the timing mark on the flywheel by looking up through the hole on the bottom of your torque tube, which should line up with either a very nice steel indicator or a nub cast intoon the cover in front, depending on your tractor.
From there it's pretty much like the others have said. Orient your distributor so that the rotor is pointing generally to #1, which is usually in the 1-2 o'clock position, and bolt it in. From there rotate it in until you get a spark at just that point. After that it's pretty much fine tuning by ear.
Today's Featured Article - Fordson Model N: Field Service Operations and Lubrication - by Anthony West. The daily or weekly servicing of any vehicle is of the utmost importance, and in days gone by when our favorite tractors were doing an important and Commercially vital job on the farm, these service operations would make a major difference to the running costs and economy of the farm. This being so, it surprises me to see how many enthusiasts attending rallies, shows etc, seem to be unaware of the importance of this constant attention. Possibly the modern machine with its 6,000 mile or even once
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
