First off change the hyd. filter and make sure that the hyd. oil is not milky looking .check fluid level and make sure that you are up to the full mark . Next run the tractor for about a half hour and then try turning the steering wheel to the left while running the engine up around 1500-1800 and see if she will pick up prime . Then the other thing it could be is that the Flow control valve maybe sticking . Also is the dash lite working that comes on when ya push down the clutch pedal ??? if not put a new bulb in it . IF the lite stays on after the clucth pedal is up then she is not picking up prime to the MCV pump , Then try adding three to five more gallon of Hy Tran to the system and see if this helps. If all of the above does not help then you will have to either get a I T manual and LEAN ALL ABOUT THE MCV or let someone that does get into it.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
