Okay, main question here is what do you mean by 400 engine? Do you mean the Farmall 400's C281, or a 400-series diesel engine commonly used in 66, 86, and 88 series tractors from 1973 up?
The C281 engine may bolt up with minor modifications because I suspect that the bell housing bolt pattern is the same; a 660 is just a 560 with a revved-up engine and planetary gear reductions at the rear wheels. You'll need to drill holes in the frame rails for the front engine mounts, and figure out all the fuel, electrical, and gauge hookups.
The problem with a C281 engine is that it only turns 1800RPM, while the 660's stock engine turns 2800 RPM. Ground speed will be unbearably slow; you will probably be able to plow in road gear. I suppose you could put a pulling-modified governor on the Farmall 400 engine to get the RPMs back but don't expect to use it for work unless you like rebuilding engines.
If you're talking about a D414/D436/D466, then it's going to be a huge project. Look for a D360 out of a mid '80s school bus or municipal truck if you want to put a modern diesel in the tractor.
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
