Posted by Hugh MacKay on January 06, 2009 at 02:13:46 from (216.208.58.191):
In Reply to: Tractor purchase advice posted by Leon Torkelson on January 05, 2009 at 06:14:14:
Leon: I ran my round baler with 3 different tractors, 560, 656 and 1066. About the only difference I could see, was 1066 burnt about 3 times the fuel. At the end of a days baling, they all turned out roughly same number of bales.
I think you should test the 560 pressure and volume. I think you have tractor hydraulic problems, and you may just buy that same problem in another tractor. I know I've used my 560 on hydraulic applications much more demanding than any round baler, very little difference between 560 and other tractors I've owned.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
